First post, by Destrate
I am having a problem getting DiscWorld 2 to work in Dosbox. I have mounted it with Daemontools and installed the game through Dosbox. I get the game and sound installed on Dosbox but I am unable to run the game. This is where I get lost:
. Enter the right cdrom path where your discworld 2 are mounted in Daemonstools.
Right Path Info on DW2.TXT
@echo off
Config -set cpu cycles=22215
mount d " Rename to the right path where discworld 2 are mounted on your drive ---> f:\ -t cdrom -usecd 0 -ioctl
vbeplus.exe
univbe.exe
dwb.exe
. After you have done this , save it as DW2.BAT
I enter the correct location of the cd in the txt file and I enter dosbox to run it then it says that "The DiscWorld 2 CD Cannot be located.
The mount drive is f: on daemontools and the game is installed on c. Can anybody please help me with this problem? :confused:
