Newbie Help Please
First post, by paradigm76
Ive got everything installed and got some games to work but alot of the games are really really slow, I have a new computer and thought it would makes the games if anything really fast. But they are painfully slow, is there anything I can do to speed it up?
Thanks
Reply 2 of 6, by paradigm76
DOSBox 0.72
Its a Inspiron 9400, 2GB ram, 2.0 Dual core processors
I cant remember all the games i tried out, but one of them was Veil of Darkness, those type of games
Reply 3 of 6, by DosFreak
Veil of Darkness came out in 1993 so it may be a real mode game if so then DosBox does not use auto-cycles so you'll have to use Ctrl+F11/F12 manually. (F11 to decrease cycles and F12 to increase).
It's in the README in the Start Menu under the DosBox heading.
Make your games work offline
Reply 4 of 6, by Alexander
The description of your computer looks like you are perhaps having Vista. If this is right and if you have started with the default dosbox.conf your problem is perhaps this line:
output=surface
Vista uses an other way of screen buffering (making some Delphi programs flicker when resizing and making especially fadeing in DOSBox slow). You can try "overlay" instead of "surface" which has solved this problem with nearly all slow games for me.
Reply 5 of 6, by paradigm76
Oops my bad sorry forgot to mention my OS, and no its not Vista, I got rid of that piece of garbage about a week after I got my computer, im running XP
Reply 6 of 6, by MiniMax
Rank Moderator
Moderator
I have the same type of laptop. What games are you having problems with?
_________________
