First post, by 9mmMick
Hi,
What's the best way to play Multi Player with Quake 1?
I'm using Winquake right now.
Reply 1 of 15, by leileilol
Darkplaces can connect to Quakeworld servers
most out there use Quakeworld clients like fuhquake and fteqw and ezquake (which is just fuhquake with flat skins etc and such cheaty stuff)
be warned though, everyone cheats to their advantage, though they defend it as "IT'S JOHN CARMACKS ORIGINAL VISION OF QUAKE"
Reply 2 of 15, by 9mmMick
Thanks! Now, for some reason, my options are not saving.
Reply 3 of 15, by leileilol
is config.cfg set to read only?
Reply 4 of 15, by 9mmMick
Ya, I fixed it. The .cfg file hadn't copied over in the first place.
I've got Fuhquake in there now and it's working great, but when I try connect
to play Multiplayer, it says "Connecting to <ip adress>" constantly and the Deathmatch never starts. I'm just stuck in the console.
Reply 5 of 15, by Davros
are you typing in the correct ip ?
Reply 6 of 15, by 9mmMick
Yes I am, I've tried it many times.
It keeps saying (example)
Connecting to 10.132.120.169
And never starts.
Do I have to wait awhile?
Reply 7 of 15, by MiniMax
Rank Moderator
Moderator
Why 10.132.120.169 ?
_________________
Reply 8 of 15, by leileilol
don't forget the port too. it could be anything
Reply 9 of 15, by Davros
just looked up that ip on whois
and its reserved where did you get it from
Reply 10 of 15, by 9mmMick
I just made it up for an example. I'll put in the port number to, that's probably the problem.
Like this? -- XX.XX.XXX.XXX :XXXXX
Reply 11 of 15, by MiniMax
Rank Moderator
Moderator
Why is the server address a secret?
_________________
Reply 12 of 15, by 9mmMick
It's not. I'm just showing a pattern, use which ever numbers you want to.
Reply 13 of 15, by MiniMax
Rank Moderator
Moderator
A lot of things could be wrong. Adding guesswork into the mess just makes it harder for everyone to help you. Give us the actually IP-addresses and port numbers you are using and we MIGHT be able to help.
_________________
Reply 14 of 15, by 9mmMick
Here's a link. I tried all these...
http://www.gameaholic.com/servers/quake/
But, I just read on there that I may have to add uprades...duh.
Reply 15 of 15, by franpa
nquake, nuff said.
AMD Ryzen 3700X | ASUS Crosshair Hero VIII (WiFi) | 16GB DDR4 3600MHz RAM | MSI Geforce 1070Ti 8GB | Windows 10 Pro x64.
my website
