First post, by praganzi
Hi.
New to Dosbox (using 0.71) on Ubuntu Linux.
It works great, and has resurrected some old games.
I have a problem when trying to IMGMOUNT, either from the command line or from the conf file.
[autoexec]
# Lines in this section will be run at startup.
mount c /home/nick/dos
mount d /media/cdrom0 -t cdrom
imgmount e "/home/nick/dos/dk.iso" -t iso -fs iso
c:
I changed the name from a long-winded one with spaces.
I continually get
MSCDES: Failure: Path not valid.
I have tried imgmount e c:\dk.iso and I have tried with and without quotes, and I have tried with and with -fs iso (but always with -t iso).
I have rad the imgmount readme, and did a forum search for imgmount, and read through the relavent posts from the 11 pages of results. A lot of people have had similar problems, and I have tried the pertinent fixes, but to no avail.
Can anyone see what I am doing wrong, or could it be a corrupt iso that I am going to have to re-image?
Cheers,
Nick.
Reply 1 of 3, by MiniMax
Rank Moderator
Moderator
I have never ever used that -fs option. Had to check the README to see what it was about. I doubt it is needed if the image is from a CD.
I think you are correct in suspecting a corrupt image.
Or - it could be a HD-image in FAT(16?) or some Linux format that DOSBox do not know how to handle. In that case, you should be able to mount it with
imgmount 2 "~/dos/dk.iso" -t hdd
or
imgmount 2 "~/dos/dk.iso" -t hdd -f none
But it won't be of much use to you.
_________________
Reply 2 of 3, by J.B.
I can confirm that you can get that message if there is a problem with the image. Have you tried reading the image via deamon tools?
Reply 3 of 3, by praganzi
I've just tried opening the iso with another app, and can confirm that the image is "corrupt or unreadable".
Thank you both for the help; I'm off to re-rip and see if that helps.
Cheers.
