executing batch files
First post, by fordprefect86
Hi folks,
I want to write a batch file that executes automatically in the dosbox. So I created a shortcut to dosbox and added the batch file as parameter.
The problem is, dosbox wants to mount the folder where the batch file is located as C. But, C is already mapped to my real C partition (later, I want to do this with the batch file rather than in dosbox.conf, but the problem would be the same). I need C to be mapped to my C partition, because the program I execute with the batch file uses absolute paths and only works with this configuration.
Because C is already mounted, dosbox doesn't find the batch file (it isn't located in C:\... and no, I don't want to move it there).
So my question is: Is there a way I can execute a batch directly with dosbox without needing C to be mapped to the folder where my batch is located?
Reply 1 of 5, by Qbix
Rank DOSBox Author
DOSBox Author
use the -c command when specifying parameters
Water flows down the stream
Reply 2 of 5, by MiniMax
Rank Moderator
Moderator
You need to use 2 of the -c options: One to mount a drive with your batch file, and one to execute it:
dosbox -c "mount X \path\to\folder\with\bat-file" -c "X:name.bat"
_________________
Reply 4 of 5, by fordprefect86
@collector: I don't want to lose the possibility to launch more than one application with the same dosbox installation, so I execute all the app specific commands in a batch.
@others: thanks, works fine with -c parameter.
