External CMOS batt.
First post, by Amigaz
I recently aquired an old 386 motherboard which looks pretty much like this one:
http://stason.org/TULARC/pc/motherbo...-SER-386C.html
With it came an external CMOS battery with a 4pin connector and one + and one + wire from the battery connected to it like this -+oo
o = empty hole in the connector
The external CMOS batter connector has 4 pins...the first pin is labeled "1" and the last one "4" but I have no clue on to which too pins to connect the battery without frying something...please help me
This PC will hopefully solve my speed problems I have with games like Wing Commander which even runs a bit too fast on my 386DX 40mhz 😵
Reply 1 of 12, by general_vagueness
You mean one + and one - wire, right? I had a computer with a battery like that before, they're annoying. I'm pretty sure the amount of power in the battery, and the low amount of power PCs use in general, means nothing will get fried, but I would wait for someone who knows to before trying it.
I'd rather not ask the... not obivous, but very easy, but did you look at the plug? Two of the holes (I don't think there's a technical term) may be blocked, so that you can only connect it one way. Also, if there are only two wires, the two holes that go with them are the ones you should connect, and if there are four, then it should be the black and red wires (traditional for positive [+] and negative [-]).
good luck
You cannot fall off the floor.
If you look hard enough, you'll find something you don't like.
How to ask questions the smart way
How to become a hacker
How to answer smart-alec questions
Reply 2 of 12, by StickByDos
Only first and last pins are used to connect battery, the two center pins are unused
Type win to loose the power of your computer !
Reply 3 of 12, by 5u3
On most boards, yes.
Just a matter of finding out the polarity.
@Amigaz: Got a multimeter? If not, it's time to get one now, after all you own a lot of retro hardware... 😉
A cheap one (~10 $ ) will do for most purposes.
Reply 4 of 12, by Amigaz
good luck
Yeah, one is blocked but there's four pins on the CMOS batt. connector 😜
Reply 5 of 12, by Amigaz
One of the centerpin holes in the battery connector is blocked
Reply 6 of 12, by Amigaz
5u3 wrote:
On most boards, yes. Just a matter of finding out the polarity. […]
hehe, I actually own a very expensive Fluke multimeter I use alot for trouble shooting car engines and marine engines
But how will it help me find out which two pins to connect too? I have 50/50 chance to connect it right since the + and - wires are next to each other on the battery connector which doesn't make sense if pin 1 + 4 are + & -? 🤣
Maybe the seller just threw in this battery and it doesn't belong to this motherboard 😜
Reply 7 of 12, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
One pin of the cmos battery (black) is on ground.
1+1=10
Reply 8 of 12, by Amigaz
This is how it looks, sorry for the crap photo...my photo skills are zero 😁
As you see one hole is blocked (white dot) and + and - are next to each other
Reply 9 of 12, by Amigaz
Yes, and red is positive...I use to work as a boat engine mechanic so I'm familiar with those facts 😉
Reply 10 of 12, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
well then it should be easy to find out which pin on the board is ground (with the multimeter).
The link in your first message is broken.
1+1=10
Reply 11 of 12, by StickByDos
I have a mobo where the pin 2 is missing
Reply 12 of 12, by general_vagueness
that's good enough to see how it's set up
if there's a pin missing, then of course that's where the blocked spot goes, otherwise it still will only plug in one of two ways, and I think I remember once plugging mine in backwards and not having anything fry because of it (caution, though)
