First post, by awallrab
Hi,
I'm trying to install an old Cad application called Caddy.
I tried the standard Dosbox edition and HAL9000's version, but the program
just doesn't want to install. When I run the installer it just falls back to the dos prompt without any error message. I also tried different settings for xms, ems and umb but none of these seem to have an effect.
Did anyone have a similar behaviour when installing a program or is there anyone out there who tried to install the same program ?
Any help appreciated
Regards awallrab
Reply 1 of 9, by wd
Rank DOSBox Author
DOSBox Author
So is this the standard behaviour when it finds no dongle or so?
Reply 2 of 9, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Some general hints would be to try a debugger-enabled build (-> sticky in the development forum) and see if it outputs something suspicious or boot DOS in DOSBox and install there.
1+1=10
Reply 3 of 9, by awallrab
Hello,
sorry for my late reply, but I was ill over the last week.
@wd
This application needs a dongle, but the behaviour is the same. The installer just drops back to the dos prompt.
@h-a-l9000
Thanks for the ideas ... I'll try them and reply back as soon as I have any results.
Regards
awallrab
Reply 4 of 9, by awallrab
Hello,
so I booted an MS-DOS 6.22 image, but I don't know how to access my hard drive or my floppy drive. Can anyone help ?
BTW: Before I tried dosbox I used VirtualBox and VirtualPC to run this application. Then the error message is "program too big to fit in memory".
What does this mean ? Is the installer corrupted or are EMX/XMS settings wrong ?
Regards
awallrab
Reply 6 of 9, by awallrab
Hello,
I just tried running the installer on a PII 400 and didn't have any problems.
So the error message "program too big to fit in memory" doesn't necessarily mean that a program is corrupt.
I don't know what the problem with dosbox, Virtualbox or VirtualPC is.
I used the same boot disk I used with these programs to boot the PII 400 and everything worked out fine.
Thanks for all the help
Regards
awallrab
Reply 7 of 9, by wd
Rank DOSBox Author
DOSBox Author
Indeed, hard to tell.
Reply 9 of 9, by awallrab
No, the installer file is not on the boot disk. It is on separate floppy disk.
I also made a disk image and mounted it in windows with a virtual floppy drive. But the behaviour is the same.
I don't think it makes much of a difference if the files are copied to the harddisk, but I can try.
