First post, by skwatter
- Newbie
this game just doesn't want to work.
i do everything. i follow your guide. i follow other people's guides. nothing works.
i install the game.
i mount my drives and i type install. i click "easy" install. it copies the files to my disk. i setup my working sound drivers. everything's great.
i play it using masterlu.bat in dosbox. the game runs perfectly.
however, if i want to run it again after quiting dosbox, i can't.
i do the exact same thing to play the game.
i mount my c drive (mount c c:\dosgames\riddle)
i mount my cd drive (mount d j:\ -t cdrom -ioctl) my cd drive is j:\
i type at the z prompt "C:"
i am in "C:\>"
i type "masterlu"
pauses then crashes with an error.
says this:
FATAL ERROR ENCOUNTERED:
FILE NOT FOUND
ERROR CODE: 0x0800
CODE FOUND IN: MASTER.M4E
OFFENDING EXE: RIDDLE.EXE
SOURCE CODE INDEX: ..\FILEIO\F_SYSFIL.CPP:519
PATH TO EXE: C:\
DESCRIPTION:
HASH FILE NOT FOUND: C:\RIDDLE\RIPLEY.HAS
but i DO have the hash file. that exact one in the directory of my installed masterlu (riddle).
what is this? can anyone help me?
