First post, by Sir Alock
Hi All: I'm new here. I'm so excited about finding DOSBOX. Running a ton of my old games! Anyway...I installed MAX on my rig & applied 1.04 patch. No problems. The very 1st time installed the game, I ran c:\oldgames\intrplay\max & it run w/o a problem. The issue is when I went back to play the game, I have issues.
When I try c:\oldgames\intrplay\max\max.run I get "Screen INT. Failed"
Ok...I so I try another execute command
c:\oldgames\intrply\max\dos4gw.exe I get
"DOS/4GE fatal error (1004) Syntax is DOS4GW (executable.xxx)
What gives? As my memory serves me. I always used the maxrun.exe executable when I had WIN95/98. What I'm I doing wrong?
Running DOSBOX 0.72
Specs:
WINXP
AMD Sempron 2.0GHz
2GB RAM
Asus 52X CDROM
ATI Radeon X1250 onboard graphics
Onboard Sound
Within MAX sound I use normal "Sound Blaster" 220/5/1
Any & all insight would be so very much appreciated!
Thanks!
Alex
