First post, by thesnare
If you have a program with dosbox where if you try to use the install.exe or setup.exe files from within the program, and it asks you to insert the floppy or CD (thinking you have them) should you mount the directory as the CD and run it from there like this
mount C: C:\oldgames\PQ1 -iotcl
cd pq1
install
Reply 1 of 2, by MiniMax
Rank Moderator
Moderator
mount C: C:\oldgames\PQ1 -t cdrom
install
_________________
Reply 2 of 2, by eL_PuSHeR
CD-ROM letter should be greater than C.
I would do:
mount c c:\oldgames
mount d C:\oldgames\PQ1 -t cdrom
d:
install
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
