First post, by oKIeh
Hello!
I've got a very annoying problem with the riddle of master lu. I'm not sure its just a bug in the game, or its a bug of dosbox.
Anyway, I'm using dosbox 0.72 to run this game, the game runs fine most of the time. I've experienced some crashes on several locations, but mostly I could avoid them or I didn't encounter them a second time.
But now I'm in the end of the game and every time I try to enter the tombe/temple on the other side of the mercury lake, the game crashes with the following message:
FATAL ERROR ENCOUNTERED:
<Could not locate description>
Error code: 0x0301
Code found in: F
Offending EXE: RIDDLE.EXE
Source code index: ..\adv_r\adv_been.cpp:155
Path to EXE: C:\GAMES\RIDDLE\
Description:
player_enters_scene()
What did I try?
1. Running dosbox in windows instead of linux.
2. Running dosbox 0.65 (default in Ubuntu 7.04) instead of 0.72
3. Tried to run the game on another machine (dosbox 0.72)
4. Tried to change some dosbox settings (memory = 16mb and 64mb, core to normal or dynamic)
5. Tried to setup another sound card for the game
6. Tried to use medium installation instead of full installation
Anybody any idea if this is a bug in the game, or a bug causes by dosbox? Does anybody know a workarround? I really would like to see the final scene of the game.
