First post, by ErikErikson
Hi,
I am running discworld 1 on vista under dosbox. I cant get the speech to work, yet the music is working. I already tried every possible option within the config.
I just mounted the game and changed nothing in dosbox.
Please help! The game is not so good without speech.
Reply 1 of 7, by MiniMax
Rank Moderator
Moderator
Read my 60 Seconds Guide to DOSBox.
(and don't just read it - follow it too)
If that doesn't help, come back with details on how you mounted your C and D drives, how you did the install, how you configured sound, music etc.
_________________
Reply 2 of 7, by Freddo
If you do have the CD version of the game, then download the patch. It fixes several issues with Discworld, and improve the sound system too.
Reply 3 of 7, by ErikErikson
I did read the manual, but t didnt realy help. I tried that already.
I do not have the cd version, but downloaded it from abandonia. I tried the Patch, but then, it tells me that I have no cd. And since I do not have one...
I mounted it that way:
mount c c:\discworld\discwld
I did not mount a d drive, is this the problem?
Reply 5 of 7, by ErikErikson
You are mean.
Reply 6 of 7, by Kippesoep
He's not being mean, it is the forum policy. And it's quite possible that the version you downloaded simply doesn't contain the speech files anyway, as is common for rips.
My site: Ramblings on mostly tech stuff.
Reply 7 of 7, by wd
Rank DOSBox Author
DOSBox Author
closed. And no, Dominus is not mean.
