First post, by Pokerbulle
Hi there...
I'm running DosBox with the Dapplegrey-frontend on OSX 10.5 ...
my monitors nromal resolution is 1680x1050....
and now my question:
I want to play DOS-games fullscreen... that works fine -- BUT the games are stretched so they fill up the whole screen... and therefore, all the graphics are looking wider as they should.
is there a way to get "black bars" on the left and right to get the correct ratio - while keeping it filling up the screen from top to bottom?
thanks for your help and sorry for my bad english 🙁
PS: On my mac, i just could not find the config file - on the pc it was obvious 🙁
Reply 1 of 3, by IIGS_User
Is it located in your "yourname/Library/Preferences"?
If not, maybe in the installed DOSBox folder.
Klimawandel.
Reply 2 of 3, by Pokerbulle
ah.. i found it.. but what should i do with it to solve my problem?
Reply 3 of 3, by ADDiCT
aspect=true in the DOSBox config file.
