First post, by swaaye
Did you know that Crusader No Remorse and No Regret can mix audio at up to 48KHz? I was digging in Regret's Crusader.cfg file and found "mixrate" 😀. It defaults to 22050 Hz it seems. I upped that to 48000 Hz as that's what my Ensoniq Soundscape can do natively, and WOW does it sound a lot better! Not just the tracker music, but digital audio too.
44.1 KHz should be safe for a SB16 and any other 16-bit card, actually. I just happened to know that Soundscape can do 48KHz so jumped up to that.
