First post, by retro games
As per subject line, these rig components produce flickering graphics at the bottom of the screen where the HUD and ammo icons are. Swapping out the cable for a 15-pin D-Sub cable removed these graphical glitches. I have not tested this scenario with a single link DVI cable as I don't own one. (Please note that other DOS games run fine using the dual link DVI cable.)
In my ignorance, when purchasing a DVI cable, I opted for the dual link not really knowing what I needed the "dual part" for. Perhaps for my needs a single link cable would have been better as I do not require a resolution higher than 1280x1024.
Best regards, Robert.
Reply 1 of 3, by retro games
Perhaps I should have mentioned the rig setup -
Win98 pure DOS mode, Radeon 9250, 5:4 LCD, Pentium 3.
Reply 2 of 3, by swaaye
I know that DX8-generation Radeons have some DVI issues. They were ATI's first (or at least some of the earliest) boards with DVI. If you do some searching you will quickly find talk of DVI issues with Radeon 7500, 8500. Still, 9200 is a refined 9000, which itself was a refined 8500. You'd think they'd have figured it out by then.
My first choice would be to blame the Radeon. Try analog output instead. If it's still flickering, I'd blame Radeon's DOS support which is not very good really.
Reply 3 of 3, by Snover
Dual-link provides increased bandwidth by doubling the number of data-pins. At the sort of resolution you're likely to be running a DOS application at, in all likelihood are those pins aren't even being utilised. So, I wouldn't bother trying to find a single-link cable.
Yes, it’s my fault.
