First post, by pepemorph
Moderator: Split from this thread.
hi my name is pepemorph and can you guys please tell me plain and simple how to play fix the error message: SDL_Init: Starting up with SDL windib video driver.
Try to update your video card and directx drivers!
CONFIG:Loading primary settings from config file dosbox.conf
MIDI:Opened device:win32
Failed to create ddraw surface, back to normal surface.
for my win vista pc. please help
Reply 2 of 7, by pepemorph
okay dosfreak yes my video card drivers are up to date and my video card is an nvidia geforce 6150se nforce 430. appreciate your reply and please try to help me solve my problem.thank you!
Reply 4 of 7, by MiniMax
Rank Moderator
Moderator
pepemorph, which version of DOSBox are you using? Have you changed anything in its configuration, or is everything set to default?
_________________
Reply 5 of 7, by pepemorph
i use dosbox 0.72. i do sometimes use windib so that i dont get the faluire to create hardware error and i change the config file to fullscreen=true and memsize=63. so no not everything is not set to default minimax. please help anyone.
Reply 6 of 7, by wd
Rank DOSBox Author
DOSBox Author
check the readme (troubleshoot section)
Reply 7 of 7, by MiniMax
Rank Moderator
Moderator
You sometimes use windib? How? By setting the environment variable SDL_VIDEODRIVER to windib before running DOSBox?
The memsize=63 should not affect the screen, but does it also happend with fullscreen=false ?
_________________
