First post, by DarknessKnight
I've bought a thrustmaster usb joystick to play strike commander CD, i plug in and start to play and it freezes in the auto calibrate cuz the buttons dont work. Dosbox joystick lines are as follow:
joysticktype=auto
timed=false
autofire=true
swap34=false
buttonwrap=true
Dxdiag excert:
Time of this report: 3/29/2008, 20:31:14
Machine name: DARKNESSKNIGMOB
Operating System: Windows Vista™ Home Premium (6.0, Build 6000) (6000.vista_gdr.071023-1545)
Language: Portuguese (Regional Setting: Portuguese)
System Manufacturer: Acer
System Model: Aspire 7720
BIOS: Default System BIOS
Processor: Intel(R) Core(TM)2 Duo CPU T5250 @ 1.50GHz (2 CPUs), ~1.5GHz
Memory: 2046MB RAM
Page File: 1422MB used, 2883MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 10
DX Setup Parameters: Not found
DxDiag Version: 6.00.6000.16386 32bit Unicode
Im out of ideas, anyone had this problem and solved it?
Reply 1 of 1, by DarknessKnight
my appoligies i forgot to post this, how i mounted the game.
mount c d:\games dir\sc
mount d f:\ -t cdrom
Joystick is working fine in vista in control panel and playing right now descent freespace 2 perfectly, just not dosbox games (tried Tie fighters special edition, strike commander cd and now x-wing cd, none recognizes the joystick AFTER i tried all options in the tutorial)
