config.sys + DOSBox
First post, by MASTER-L
Hi all! Peoples, plz, help.
I tried to run in DOSBox once database program for DOS, but it writes that "config.sys doesn't found" and don't run it. (this DOS program can't found config.sys file)
moreover, this program (when i run it on real DOS) needs, that in config.sys file was a string "FILES=200"
where is config.sys files in a DOSBox? how i change this file? and how database program help to found this file?
Reply 1 of 2, by wd
Rank DOSBox Author
DOSBox Author
Create one in the directory that you mount as your c-drive.
Reply 2 of 2, by MASTER-L
oh, tnx! that's it.
