First post, by DOSfungame
Hanse needs SVGA. I can start it but the grafik is not shown only the text. I try to start the game mit Hanse_V.bat (univesa) but then it breaks direktly.
Is that a know problem because I can't find a Hanse problem in that topic? Hanse from Ariola is supportet in 0.70.
During the DOS (1996) time (1996) I got from ASCARON a update HANSE3.exe for ATI grafik card problem but this patch didn't help in that case.
Thanks for help.
Reply 1 of 10, by eL_PuSHeR
You mentioned DOSBox 0.70
[MOVED]
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 2 of 10, by DOSfungame
Hanse / Ariola is older than Hanse / ASCARON. This game is a remake from 1995.
Reply 3 of 10, by DOSfungame
Try to play Hanse /ASCARON on following system:
MS XP SP2
Motherbord MSI K7N2 Delta2
AMD Sempron 2600+ 1.83GhZ
NVIDIA GeForce 6600 Driver 6.14.11.6375
1,50 GB DDR SDRAM
486 DX-66, 8MB RAM, MS Mous, SVGA, Soundblaster you need for the game
Sound is ok.
Grafik start with wrong background colour normal is beige and now turquoise
with - (minus) in the screen see the file.
I hope this informations will help to find the problem. Can I do something like a debug log to find the failure better?
thx
Reply 4 of 10, by DOSfungame
In the normal display you see Lübeck ship, houses, store, etc.
Reply 5 of 10, by wd
Rank DOSBox Author
DOSBox Author
Looks like your installation is corrupt. But even with a working installation
i could not get the game to work, it loops at the beginning.
Reply 6 of 10, by DOSfungame
I install it brand new on two diffrent PCs with DOSbox 0.72 same result. The install CD has no problems during installation. I have no loop an if I finde the right place in the screen I can sell or buy thinks and so on. I don't now if the dosbox works with SVGA.
Reply 7 of 10, by wd
Rank DOSBox Author
DOSBox Author
dosbox works fine with svga/vesa usually, the target chipset is s3.
Maybe try univbe, though it looks more like missing/incomplete unpacking
of the files (try browsing that "Daten" directory).
Reply 8 of 10, by DOSfungame
I try univbe but i didn't help please have a look to log file.
And this game has an univesa.exe and it will start with hanse_v.bat but it doesn't help too.
But I found a old topic with same problem ( http://www.oldgames.nu/forum/showthread.php?s … &threadid=54017 )
Maybye some one has mor ideas.
I set a mount c c:\dosspiele so it is c like in that game 😕
Reply 9 of 10, by wd
Rank DOSBox Author
DOSBox Author
No relevant critical thing in the log. Modes are fine.
Reply 10 of 10, by DOSfungame
Ok I think I found my failure. This game has to be installed in the DOSbox
Before I copy hanse1-3 in a folder at C: and extrakt all files out of the box.
mount c c:\ -t
mount d f:\ -t cdrom -ioct -label hanse
type install an follow the instruction of the game and grafik and game are fine working.
Thx for ideas
