dosbox crashes black screen with sentences on any game
First post, by pepemorph
please help me on dosbox
Reply 1 of 12, by pepemorph
well just ignore the first post and get to my problem dosbox fans. well when i play any game it crashes and shows a black screen with some writing on it. the dosbox status window doesnt get an error message though. also i use windib video driver because i am using vista.
here is a screen shot for you guys.please help
    9.91 KiB
    this is what happens when it crashes.
Reply 4 of 12, by dvwjr
pepmorph wrote:
can you guys please help me on my games anyone!
Perhaps you should first make certain Dosbox is properly installed.
Ensure that you read the Dosbox README file.
Please confirm you have set proper VISTA permissions.
Make sure to properly mount the game sub-directory.
Original DOS games have DOS installers.
Repeat any game setup already performed under Dosbox.
Put a mount command for your CD-ROM as drive D:.
Have the DOS installer load all files.
You should select the proper emulated sound card.
Other soundcard choices can be auditioned with Dosbox.
Unselect any unused emulated soundcards in DOSBOX.CONF.
Many times using the Dosbox scaler functions helps older games.
Otherwise the game screen appears too small on today's monitors.
Remember to set the emulated CPU cycles to around 4,000 to 6,000.
On some PC systems try different output= choices for best performance.
Never think that Dosbox can not run older DOS games, it works well.
dvwjr
Reply 7 of 12, by MiniMax
Rank Moderator
Moderator
Read my 60 Seconds Guide to DOSBox (and don't just read it - follow it too).
If that doesn't help, come back with details on how you mounted your C and D drives, how you did the install, how you configured sound, music etc.
_________________
Reply 8 of 12, by ADDiCT
And it would also help to know which game you're talking about. Dear pepemorph, please stop writing in the style of a 6-year-old dyslexic with a brain tumor (this is not the first time you're doing that, btw.).
P.S.: please forgive me if you actually _are_ a 6-year-old dyslexic with a brain tumor
Reply 10 of 12, by general_vagueness
He said any game, I think he means any game.
To be clear, though, pepemorph, which games did you run that caused this?
Dang, I wish I had that kind of time... but you left out the second "e".
You cannot fall off the floor.
If you look hard enough, you'll find something you don't like.
How to ask questions the smart way
How to become a hacker
How to answer smart-alec questions
Reply 11 of 12, by ADDiCT
Ah, general_vagueness, the misunderstood philanthropist. If you're desperate to raise your karma level, try to help pepemorph by PM (or phone, fax, by meeting him in person, marrying him, etc. - it doesn't matter, as long as we're not forced to read his spastic posts anymore). I'm sure you two would get along nicely. It could be the beginning of a wonderful friendship.
P.S.: i'm amazed by the fact that you have discovered that pepemorph owns every game known to mankind, and has tried to run them all in DOSBox - only to find out they're crashing. Oh, the irony.
Reply 12 of 12, by MiniMax
Rank Moderator
Moderator
Is it that hard to stay on topic?
_________________
