First post, by tomaswoj
Howdy,
im now strugling to recompile dosbox for symbian 😀. It seems that some of the header files are not used at all, for example decoder.h in /src/cpu/*/*.
At least I was not able to find "#include "decoder.h" in the source tree.
Is that correct ? Im getting many compilation errors from some of these header files, and would like to exclude them, if they are obsoleted for any reason.
Cheers
tomaswoj
Reply 1 of 3, by wd
Rank DOSBox Author
DOSBox Author
They are used for the recompilers, which is disabled for non-x86 so something
with your configure scripts is messed up.
Reply 2 of 3, by tomaswoj
Hi WD,
thanks for this info. However i now stepped into another problem. When trying to compile core_full.cpp, im getting errors about declaration syntax error in core_full/string.h.
And indeed the file looks odd, as it begins with:
EAPoint si_base,di_base;
Bitu si_index,di_index;
Bitu add_mask;
Bitu count,count_left;
Bits add_index;
Forgive my ignorance, but what kind of construct is this ?? It seems to be a body of some function (class??) but i cannot see the class itself. Is it concatenated with something during the build ??
On the other hand, string.h in core_normal looks much more sensible.
In general - is there any intro for dummies on DOSBOX build system ? 😀
Cheers
tomaswoj
Reply 3 of 3, by Qbix
Rank DOSBox Author
DOSBox Author
which compiler are you using ?
dosbox includes the h files in the cpu cores are part of switches
(like this:
swich(a) {
#include "header"
Just browse core_full.cpp. It is a very small file.
oh and please give the precise error if you get an error.
Water flows down the stream
