First post, by Grathus
I am trying to get Conquest of the New World to run on my friends computer. It works with no problems on XP. But when i try to load it on vista all i get is a blank screen. I have not messed around with the settings yet but i plan on it here in a few mins...
commands i used for mounting
mount c c:\game DIR
mount d c:\cd DIR -t cdrom
also tried
mount d c:\cd DIR -t cdrom -ioctl
I loaded the CD on to the hrad drive. works fine on XP.
is there anything i need to do to get it running on Vista
Reply 1 of 5, by wd
Rank DOSBox Author
DOSBox Author
fullscreen? Be sure you stick to windowed mode for testing at first.
Did you install the game under vista+dosbox?
Reply 2 of 5, by Grathus
Im usein window mode.
im installing useing Dosbox. very slow install...
i also should add i did get installed without dosbox but when i run it to play that is when i get the blank screen.
Reply 3 of 5, by wd
Rank DOSBox Author
DOSBox Author
What do you get when you install it within dosbox under vista?
How to speed up things is in the readme.
Reply 4 of 5, by Grathus
useing Dosbox it loads the cdrom files normal but when it is "Building conquest of the newworld" it is EXTREAMLY slow. but everything looks fine.
not useing Dosbox. i was able to install it just fine and nor speed. but when i try to run it in window mode it just gives me a blank screen...
Now i am thinking that it is just EXTREALY Slow also when trying to play in on vista.
Reply 5 of 5, by Grathus
After the VERY LONG install it is running smoth with no tweaking of the config file
Thanks for the quick respond 😁!!!
