First post, by crash.
When I try to run Carmageddon with Glidos and VDMS, I get this error:
Configuration - COM Error
Unable to initialize and configure emulation module 'Joystick Controller'. 0x80004004 - Operation aborted
Could not locate the configuration property 'MapFile' in either of the
[Joystick Controller.config] or [*.config] INI sections (see
C:\PROGRA~1\VDMSound\VDMS.INI:244). Do you want to continue?
Help !
