First post, by Morning Song
I'm trying to use a Gravis Xterminator USB controller in dosbox, and it has two analog triggers on the top that map to axis 5. When i try to map this to any of the axes in the Dosbox mapper, it doesn't respond.
To clarify, i don't need DOS games to see more than four axes, just to let dosbox map axis 5 to one of those four.
Thanks!
