First post, by spectrum
Hello all,
i am using dosbox in Leopard Os X to compile some assembly files with TASM.EXE, it works really fine.
My problem by the way is to invoke dosbox from a makefile, like
dosbox tasm.exe parameter1 parameter2
i see that only the first parameter "tasm.exe" is passed to dosbox, other are discarded.
Then, after the file has been compiled, dosbox should close automatically.
If any help,
many thanks,
spectrum
Reply 1 of 1, by Qbix
Rank DOSBox Author
DOSBox Author
use the -c parameter
like this
dosbox -c "mount c something" -c "c:" -c " tasm.exe parameter1 parameter2" -c "exit"
Water flows down the stream
