First post, by Brikas94
I payed for Glidos yesterday... I was happy with it... I unlocked it... no problems so far... I passed some levels... everything was ok... Today, when I turned my computer on, my Glidos ID had changed... and the spinning logo had returned! What can I do? Will this happen everytime I reboot my PC? I went to the glidos site again, and unlocked it again, using the new ID... can I do this everytime I restart my PC, or is there a limit in the number of unlock codes I can get? 😢
Please help, Paul... all help is welcome... thanks... 🙁
1+1=2
Reply 3 of 14, by Glidos
Would you download the attached program , run it, press "Test" and paste the results in a a reply? I may be able to figure out what's going on from that.
    MIBTest.exe
    20 KiB
    643 downloads
Reply 4 of 14, by Brikas94
The test showed this:
[0,24] (Software Loopback Interface 1)
[1,131] (WAN Miniport (L2TP))
[2,131] 50-50-54-50-30-30 (WAN Miniport (PPTP))
[3,23] 33-50-6F-45-30-30 (WAN Miniport (PPPOE))
[4,6] A4-6B-20-52-41-53 (Miniporta WAN (IPv6))
[5,6] A4-6B-20-52-41-53 (Miniport WAN (IP))
[6,23] 20-41-53-59-4E-FF (Adaptador assíncrono de RAS)
[7,6] 00-1E-8C-B7-2E-42 (Realtek RTL8168C/8111C Family PCI-E Gigabit Ethernet NIC (NDIS 6.0))
[8,6] A4-6B-20-52-41-53 (Miniporta WAN (IPv6) - Symantec Network Security Miniport)
[9,6] A4-6B-20-52-41-53 (Miniport WAN (IP) - Symantec Network Security Miniport)
[10,6] 00-1E-8C-B7-2E-42 (Realtek RTL8168C/8111C Family PCI-E Gigabit Ethernet NIC (NDIS 6.0) - Symantec Network Security Miniport)
[11,23] 4D-65-64-69-61-30 (USB ADSL2 WAN Adapter)
[12,131] 00-00-00-00-00-00-00-E0 (6TO4 Adapter)
[13,131] 00-00-00-00-00-00-00-E0 (6TO4 Adapter)
[14,131] 00-00-00-00-00-00-00-E0 (isatap.{580686E9-A02E-46F6-9416-E62B87D7D792})
[15,131] 00-00-00-00-00-00-00-E0 (6TO4 Adapter)
[16,131] 00-00-00-00-00-00-00-E0 (isatap.{0B8AEB4E-B1CA-456B-98C9-8F4AB4DE9527})
[17,131] 00-00-00-00-00-00-00-E0 (6TO4 Adapter)
[18,131] 00-00-00-00-00-00-00-E0 (6TO4 Adapter)
[19,131] 00-00-00-00-00-00-00-E0 (6TO4 Adapter)
[20,131] 00-00-00-00-00-00-00-E0 (6TO4 Adapter)
[21,131] 00-00-00-00-00-00-00-E0 (6TO4 Adapter)
[22,131] 00-00-00-00-00-00-00-E0 (6TO4 Adapter)
[23,131] 00-00-00-00-00-00-00-E0 (6TO4 Adapter)
[24,131] 00-00-00-00-00-00-00-E0 (6TO4 Adapter)
[25,131] 00-00-00-00-00-00-00-E0 (isatap.{0B8AEB4E-B1CA-456B-98C9-8F4AB4DE9527})
[26,131] 00-00-00-00-00-00-00-E0 (6TO4 Adapter)
[27,131] 00-00-00-00-00-00-00-E0 (isatap.{580686E9-A02E-46F6-9416-E62B87D7D792})
[28,131] 00-00-00-00-00-00-00-E0 (6TO4 Adapter)
[29,131] 00-00-00-00-00-00-00-E0 (isatap.{0B8AEB4E-B1CA-456B-98C9-8F4AB4DE9527})
[30,131] 00-00-00-00-00-00-00-E0 (isatap.{0B8AEB4E-B1CA-456B-98C9-8F4AB4DE9527})
[31,131] 00-00-00-00-00-00-00-E0 (isatap.{0B8AEB4E-B1CA-456B-98C9-8F4AB4DE9527})
[32,23] (SAPO ADSL)
[33,6] A4-6B-20-52-41-53 (Miniporta WAN (IPv6) - Symantec Network Security Miniport-QoS Packet Scheduler-0000)
[34,6] A4-6B-20-52-41-53 (Miniport WAN (IP) - Symantec Network Security Miniport-QoS Packet Scheduler-0000)
[35,6] 00-1E-8C-B7-2E-42 (Realtek RTL8168C/8111C Family PCI-E Gigabit Ethernet NIC (NDIS 6.0) - Symantec Network Security Miniport-QoS Packet Scheduler-0000)
[36,131] 00-00-00-00-00-00-00-E0 (Placa Microsoft ISATAP #8)
[37,131] 00-00-00-00-00-00-00-E0 (Placa Microsoft 6to4 #10)
1+1=2
Reply 6 of 14, by Brikas94
Sure... the test showed:
[4,6] 04-A2-20-52-41-53 (Miniporta WAN (IPv6))
[5,6] 04-A2-20-52-41-53 (Miniport WAN (IP))
[8,6] 04-A2-20-52-41-53 (Miniporta WAN (IPv6) - Symantec Network Security Miniport)
[9,6] 04-A2-20-52-41-53 (Miniport WAN (IP) - Symantec Network Security Miniport)
[32,6] 04-A2-20-52-41-53 (Miniporta WAN (IPv6) - Symantec Network Security Miniport-QoS Packet Scheduler-0000)
[33,6] 04-A2-20-52-41-53 (Miniport WAN (IP) - Symantec Network Security Miniport-QoS Packet Scheduler-0000)
[34,6] 00-1E-8C-B7-2E-42 (Realtek RTL8168C/8111C Family PCI-E Gigabit Ethernet NIC (NDIS 6.0) - Symantec Network Security Miniport-QoS Packet Scheduler-0000)
[35,23] (SAPO ADSL)
1+1=2
Reply 9 of 14, by MiniMax
Rank Moderator
Moderator
Actually, you should upgrade to 1.41.
_________________
Reply 11 of 14, by Glidos
Brikas94 wrote:
How do I do that?
Just delete your C:\Program Files\Glidos folder, download v1.41 from http://www.glidos.net, reinstall and unlock. All will be well.
Reply 13 of 14, by Brikas94
...When I try to unlock, it says : You have used your allocation of unlock codes...
Maybe you used the wrong e-mail address... The one I use for my Glidos account is NOT the same I use for vogons!
Is that the problem?
Do you want me to PM you the correct e-mail address?
Thanks.
BTW: The ID isn't changing anmore!
1+1=2
