only PC speaker in Loom
First post, by Unregistered
the game can be played with soundblaster but VDM only emulates it to PC speaker. how to fix this?
Reply 1 of 8, by eL_PuSHeR
Put "a" as command-line option to enable Adlib sound.
Ex. LOOM.EXE A
BTW. The music is by Tchaikovsky (or whatever is written)
Reply 2 of 8, by Unregistered
You can also get Roland MT32 sound, but there's a patch on LucasArts' site you need to run it. I have the disk version, not the CD version and I got it to work. Unfortunately, my manual's long gone...
Cush
Reply 4 of 8, by Nicht Sehr Gut
Originally posted by Unregistered the game can be played with soundblaster but VDM only emulates it to PC speaker. how to fix this?
Darn. Pusher beat me to the punch. I was going to recommend that you grab the code for SoundBlaster support, hop into a Time Machine and give it to the original LOOM programmers...but as Pusher pointed out, it supports AdLib, not SoundBlaster.
BTW, VDMSound doesn't emulate the PC-Speaker (and never will).
The best version was the CD, which used only Redbook audio. Hard-to-find nowadays...*grumble*
Reply 5 of 8, by Snover
And which someone still hasn't sent...
Yes, it’s my fault.
Reply 6 of 8, by Nicht Sehr Gut
Originally posted by Snover And which someone still hasn't sent...
You have no memory...Told you it's presently buried in a sister's friend's home...the one with the husband with the shotgun.
Reply 7 of 8, by Snover
I never professed to have a memory, and I thought you got it back..?
Yes, it’s my fault.
Reply 8 of 8, by Nicht Sehr Gut
Originally posted by Snover I never professed to have a memory, and I thought you got it back..?
No, I didn't. I did find my DIG soundtrack recently.
