First post, by arablizzard2413
I was playing around with WarCraft II and I came across a problem with the Dark Portal Expansion. Everything worked fine when I had the cd drive mounted, but when I tried using a cue/bin on imgmount it can't read files correctly.
What I did:
Z:> mount c .\root
Z:> imgmount d c:\warcraft2_x.cue -t iso
Z:> C:
C:> cd war2
C:> war2
ERROR:
Invalid data file version
Press any key...
"D:> DIR" displays the contents of the cd alright so I know it's mounted correctly, and if I rebuild the cue/bin using UltraISO and the files I copied off the cd in windows it works fine. But if I add the audio tracks to that rebuilt image (add .wav files to the .cue and burn to a cd-rw and read that image) it fails with the same error again. The original WarCraft II image works fine, but I always have problems with the expansion, maybe it's because it has 18 tracks? Also, if you try and install the game using the imgmounted drive, it fails with a copy error.
Z:> mount d d:\ -t cdrom -ioctl
That always works when I have either the original expansion cd or the burned copy, so it can't be a bad image. The game is also patched to version 1.50.
Reply 1 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
there is indeed probably something going wrong. have you for the sake of argument tried making the cue/bin with a different program ?
Water flows down the stream
Reply 2 of 4, by arablizzard2413
yes I have, and the result is always the same.
Edit: argh well I feel sheepish, it works if I dump the cd using UltraISO. Never mind 😖
Reply 3 of 4, by wd
Rank DOSBox Author
DOSBox Author
maybe compare the .cue files to see what went wrong before
Reply 4 of 4, by arablizzard2413
well now this is weird... there's a 00:02:02 difference on the cue files for dumping the original disc and removing the HFS file system (which doesn't work, even after dumping with UltraISO again) and the copy I rebuilt. Maybe the original disc just had a mastering error then?
only the rebuilt cd works if I dump it using UltraISO.
