Installing Toonstruck
First post, by leon101
Man, installing this game seems to be a puzzle in itself. I just can't get it to work. When I run the game, and click install, it installs setup files into \BURST\TOONSTRK... okay, whatever, how about installing the game! Jeeze.
So my question is.
How do you install this game!? :angry:
Reply 1 of 3, by peterferrie
run setup.exe, it copies lots of files, and creates a toonstrk.bat.
that's the game launcher. it works fine for me.
maybe your copy is bad. try the original cds.
Reply 2 of 3, by goldenpeace
Hi
read my post about using another way to play this game...
when you finish installing the game using the way I did
then you can click on the Play option from the autorun....
of course each time you wish to play this game using this way
you will need to mount both drives...
inconvenient?
after searching the Net and reading lots and lots of posts everywhere
I did not find any suitable way of playing this game
until I found this way to play the game...
Reply 3 of 3, by goldenpeace
Oops .....
actually I just tried using the autoplay ... errrrrr
after mounting the drives...\
C:
then
cd burst
cd toonstrk
toonstrk
this should start the game...
