Bad graphic in Lemmings
First post, by Sicki
Hi all
Dosbox is very Cool, but the graphics in "Lemmings" and "Oh no more Lemmings are realy bad
Look at the screen
I have extremely problems to see which lemming i can upgrade how oft (karts left of the radar)
Befor I can play the game i have to choose between VGA and EGA but bouth realy sucks
I testet in with dosbox 0.,71 and 0.72 but bouth looks same
can someone help me ?
Reply 1 of 29, by leileilol
It only affects the briefing screen.
That EGA screen is normal. Pick VGA and IBM Compatible PCs, NOT High Performance PCs.
long live PCem
FUCK "AI"
Reply 2 of 29, by Lemonzest
To fix the briefing screen you can use the aep cvs build and set machine to vgaonly.
Reply 3 of 29, by Sicki
yeah ok ....
how do i do this 🙄
Im not care about the briefing screen .... look @ 3th screen ^^ this looks realy crap 🙁
I tested all 4 options first with vga and after that with ega .. all lookes ugly
compare level 1 havoc with dosbox (1st screen) and google (2nd screen) ! 😢
Reply 4 of 29, by wd
Rank DOSBox Author
DOSBox Author
First of all upgrade your dosbox version.
Reply 5 of 29, by Sicki
"I testet in with dosbox 0.,71 and 0.72 but bouth looks same " @ first post
Reply 6 of 29, by wd
Rank DOSBox Author
DOSBox Author
Then use 0.72, not 0.71, especially when posting screenshots.
Be sure you choose VGA in the first screen, and "ugly" is not what counts,
just "same as on a real pc".
Reply 7 of 29, by Sicki
i told you that 0.71 and 0.72 looks same -.- who cares
so you want to say that this is the best option i can play with ? Yes in 0,72 and Yes i choose VGA ...
damn and i thought lemming games are supported by dosbox -.- but no they look different to the old dos and yes that#s ugly .. the colors sucks
Reply 8 of 29, by wd
Rank DOSBox Author
DOSBox Author
who cares
I do. Especially if screenshots are floating around.
Then your version is broken, or somehow hacked. As it works just fine here.
Reply 9 of 29, by ripsaw8080
Rank DOSBox Author
DOSBox Author
The screenshot you got from Google, lemmprob3.jpg, appears to be from the Amiga version of Lemmings if you compare to shots on Mobygames -- a poor comparison to the DOS version.
I didn't see a mention of you trying different video output methods in DOSBox; not that I think changing it is likely to help, but it couldn't hurt to try.
Reply 10 of 29, by Kippesoep
Actually, he's right about the EGA shots. The palette seems incorrect for the background of the toolbar, just like the mission screen in the VGA version used to be.
Reply 11 of 29, by leileilol
I find it odd that there is EGA video coming from a VGALEMMI binary
So yes it's probable that you have some lame hackedup 'abandonware' crap version as my copy does not exhibit this behavior
long live PCem
FUCK "AI"
Reply 12 of 29, by Kippesoep
Actually, VGALEMMI was also used for the EGA version. The other 2 executables are CGALEMMI (CGA, obviously) and TGALEMMI (Tandy). This is true for both versions of the game that I have. The original boxed one and the one that came with my Sound Blaster card. If yours is different, you might be the one with the abandonware version 😜
Reply 13 of 29, by leileilol
dam i was wrong! Still it's stupid to not show any VGA shots at all if it 'realy sucks'
long live PCem
FUCK "AI"
Reply 14 of 29, by Servo
Actually this makes sense; both EGA and VGA versions run in mode 0Dh (320x200 16 color), the only difference in the VGA version is it uses a different color palette where the EGA version uses the standard 16 color palette.
Although the VGA version runs in only 16 colors at 320x200 compared to the Amiga version in 64(?) colors at 640x200, the playfield looks almost identical in both; the icons/score below is much more detailed in the Amiga version. For some reason shots above don't look right, here's what I get with latest Mac version of DOSBox which looks the same as on a real PC (except for the corrupted palette on the preview screen in DOSBox, game seems to run fine);
Reply 15 of 29, by leileilol
"High Performance PCs" option provides a more colorful bar
long live PCem
FUCK "AI"
Reply 16 of 29, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Don't use "High Performance PCs" in 0.72 and older because it switches the palette on-screen which is only supported with the vgaonly setting in CVS builds.
1+1=10
Reply 17 of 29, by red_avatar
Odd - that never worked for me when I tried the latest CVS.
Reply 18 of 29, by wd
Rank DOSBox Author
DOSBox Author
That never worked at all. In the cvs change the machine= to vgaonly (NOT vga).
Reply 19 of 29, by red_avatar
That's what I just said I tried 😜 It does not work! I just tried it again with today's CVS and nope, still got the corruption even if I change it to vgaonly.
EDIT: I discovered that I had to make Dosbox create a new dosbox.conf - the old one was not compatible with the new CVS because a lot of values are changed.
It works now, but for some reason, vgaonly is incompatible with a lot of settings - scalers don't work, fulldouble doesn't work, it ignores the resolutions, etc. I hope this gets "fixed" for 0.73 😀
