First post, by herc
Hello everybody!
i would like to play nyet III with soundblaster enabled.
NyetIII is a very creative and original take on tetris - see here:
http://www.link.deleted.by.moderator
its running very nicely in dosbox, except the thing if i enable soundblaster support. (you have to run install.exe to configure the game to use soundblaster).
in the tetrisconcept.com forum, a nice user reported that he managed to run nyet III in dosbox and soundblaster support, but he has windows 98.
i tried both dosbox and windows xp / vista, and the game always hangs after am short, audible sb initialization klick. i tried many different sb settings, but the game always hangs. so given the case that one user managed to get it to run with win98, maybe there is a bug in dosbox? or i am doing something terribly wrong...
i also got a zip file with the exact configuration of the dosbox+nyetIII that runs fine for the one user and his win98, but this setup also hangs directly after sound init of the game.
maybe someone can try test if he manages to get it to work?
thanks in advance !
