First post, by chynx
With my NVidia driver I can rotate my screen.
That works fine in dosbox window mode but if I go to fullscreen it rotates back (doesn´t get the rotated 1024x1280 resultion).
I know it wouldn´t be the right ratio (you could have two 'black bars' to retain the correct ratio).
Is there a possibility to include a patch that it also works for rotated screens?
Greetings and thanks
Reply 1 of 1, by jal
Probably that's very OS dependent, and probablty it is in SDL, not DOSBox. So I wouldn't hold your breath.
JAL
