First post, by jargon
jargon
Offline
- Newbie
-specs-
Win32 XP Home version 2002 / build 2600 SP3
Compaq Presario 906US Laptop
AMD Athlon32 "XP" 1500+ 1.33 GHz
960 MB of RAM out of a total 3 GB of DDR2 reported available.
ATI Mobility Radeon
-regarding-
This is a general error, in my opinion, independent of system specs; regarding command prompt erratic behavior resulting from wildcard usage.
>COPY * ..\DAT\
0 File(s) copied.
>COPY * ..\DAT\*
0 File(s) copied.
>COPY *.TXT ..\DAT\*
Copy failure : ..\DAT\*.
0 File(s) copied.
>COPY *.TXT ..\DAT\*.*
Copy failure : ..\DAT\*.*.
0 File(s) copied.
>COPY *.* ..\DAT\*
0 File(s) copied.
>COPY *.* ..\DAT
COPY.TXT
FLAG.TXT
FONT.TXT
ITEMROOM.TXT
NOUNVERB.TXT
VERB.TXT
WALLROOM.TXT
WHAT.TXT
8 File(s) copied.
>VER
DOSBox version 0.72. Reported DOS version 5.0.
As you can see, DOSBOX is behaving erratically with wildcards.
>COPY * ..\DAT\
0 File(s) copied.
The above should normally copy all files regardless whether they have an extension or not. There were 8 files to be copied, that would normally have copied over, I believe, in DOS 5.
