First post, by Revan2008
Hi, I'm new here and this is my first post. I have seen on The Unnoficial Elder Scrolls Pages on Daggerfall that I can play it under Microsoft Virtual PC 2004 if I have DOS 6.3 or Microsoft Windows 95.
Can someone please tell me how to make it work using Microsoft Virtual PC?
Here's the link: http://www.uesp.net/wiki/Daggerfall:Running_under_Windows
Reply 1 of 4, by MiniMax
Rank Moderator
Moderator
Any particular reason why you want to go that cumbersome route? Can't you run the game in DOSBox?
They even have the same type of guide for it here:
http://www.uesp.net/wiki/Daggerfall:Running_Under_DOSBox
PS: I don't why a special guide is needed. I assume the 60 Seconds Guide to DOSBox will work fine.
_________________
Reply 2 of 4, by DosFreak
Running DaggerFall in VPC won't solve the bugs caused by too fast processor speed.
Just use DOSBox like everyone else. If your computer isn't fast enough then upgrade to something made within the past 4 years.
Make your games work offline
Reply 3 of 4, by Syphro21
What solves the bugs caused by too fast processor speed? I've been lurking all over (or not enough) and haven't found a proper answer, aside of somehow acquiring a decade old machine.
Reply 4 of 4, by MiniMax
Rank Moderator
Moderator
Learning to read will solve the speed bug.
_________________
