DJGPP
First post, by benheath
Hello all, first post here.
I guess this could be moved to General, but it is development nonetheless. On a truly masochistic whim, I wanted to see if Dosbox could run DJGPP so I could try some dos development. I installed DJGPP following its instructions (as adapted for Dosbox) and upon running gcc -v, I get the following:
C:\> gcc -v
Load error: no DPMI - Get csdpmi*b.zip
csdpmi5b.zip *has* been unzipped properly, but all the programs in DJGPP seem to complain about this. Rhide says something similar, and so does as.
So, what's up? Should I quit now (probably 😜) or just cross-compile under Unix (since I'm using FreeBSD)? Has anyone else tried to develop new DOS apps with Dosbox?
Thanks ahead of time 😀
Ben
Reply 1 of 5, by wd
Rank DOSBox Author
DOSBox Author
check that this gcc.exe and cwsdpmi.exe files are in the same directory
Reply 2 of 5, by benheath
That did it! Upon extraction, cwsdpmi* was extracted to BIN, which BSD differentiated from bin, to which everything else was extracted.
Thanks wd!
edit: Heh, rhide works just fine and a quick Hello World program in C compiles and runs. Fantastic.
Reply 3 of 5, by leileilol
nvm i got it
Reply 4 of 5, by Snev
How do you set environment variables in dosbox for djgpp? I tried running a bat script but that didnt work.
Greets, Snev
Reply 5 of 5, by wd
Rank DOSBox Author
DOSBox Author
set
