First post, by urbanastro
Hi
I have a question about addressing a printer port, here's some background.
I am running kubuntu 8.04 on which I recently installed dosbox. I have a DOS program called scope.exe that I have used on an old 486 laptop for several years to control a stepper motor based telescope control system. The software works using the printer port of the computer in real time to send signals to the stepper controller. Can dosbox control the printer port in real time? My old laptop (over 10 years old) has left this world after a long productive life and I would like go with a linux based system.
Thanks in advance for your help
Reply 1 of 4, by MiniMax
Rank Moderator
Moderator
DOSBox is not good for real time applications. It can barely keep track of the current date (think there is a patch going into the next version that will improve it, but not on a milli-second level which I think you need for controlling a stepper motor).
Or is it just a matter of sending the correct number of pulses to the motor? And not timed pulses?
_________________
Reply 2 of 4, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Hm in Linux... the code is ready but no build with it yet...
Can you apply a patch to DOSBox CVS and build it in Linux?
It's not supported by official DOSBox.
but when it's done you
1+1=10
Reply 3 of 4, by urbanastro
Thanks for the quick answer!
The controller works directly from the pulses that appear at pins 10 thru 13 of the printer port. The software controls all the timing of the pulses which can be up to 40 microsteps for each full step.
I'm just looking for a solution that would not require me to use two laptops in the field.
