First post, by jutt69
I need some help with DosBox, I have it running on ydl6 on a ps3. I'm using a HDTV (Sony Bravia) set to 720p.
When I go to fullscreen mode (Alt + Enter) all I get is the same sized screen on a black background. I have tried fiddling with the settings but with no luck.
Any help would be much appreciated.
Reply 1 of 6, by Qbix
Rank DOSBox Author
DOSBox Author
try reading one of the other threads here. I think there are 3 with your problem on the first page.
Water flows down the stream
Reply 3 of 6, by MiniMax
Rank Moderator
Moderator
And what have you done to try to solve the problem? There is no point in us posting suggestions that you have already tried.
_________________
Reply 4 of 6, by jutt69
Yeah, you've got a point there.
I have tried changing the "fullresolution" line in dosbox.conf to many different resolutions. I have also tried changing the "aspect" line and tried all the available "scaler" options. I have spent hours trying different combinations of the above options and so far nothing works. The only difference I have noticed is that on some resolutions when Alt+Enter is hit DosBox closes!!??!
Thank you for taking the time to respond. This was supposed to be my easy project, setting up Samba is next but I think I might be out of my depth!!!!
Reply 5 of 6, by MiniMax
Rank Moderator
Moderator
The primary settings are the full-resolution and the output-methods. Scalers, aspect correction etc are secondary. I would set scaler=none, aspect=false to a start.
fullresolution should be set to the best, native resolution your monitor can handle. I am not sure about that PS3 + HDTV combination. Is it wide-screen? Maybe something like
fullresolution=800x600
will do? You could also try a "secret" setting
fullresolution=0x0
And then try that with different output methods.
_________________
Reply 6 of 6, by ripa
fullresolution=1280x720
output=opengl # or openglnb if you like it sharp
aspect=true
Should give you a nice pillarboxed view. If you want it stretched then use fullresolution=960x720 or something 4:3 and have your display stretch it.
