First post, by SpecterFan
First of all - thanks in advance for taking the time to read this. ANY help will be greatly appreciated.
I have a program which I need to install. My wife helped me install it on an older PC some years ago but that PC was lost in a fire several years ago. My wife passed away in '99. What little I know about computers I have had to pick up on my own and this is beyond me.
The program in question is the AUTODESK Collection Plus from Addison-Wesley. During installation you are presented with the option to install in either DOS or Windows. Several additional modules can also be installed. This is all carried out via a small program (which I believe is a batch file) which must be installed first called AWCD. This is installed in DOS. This is where I need your help.
Once I get to this point, I need a mouse but because I am in DOS I don't have one.
There must be a way to install this program with the aid of DOSBox.
I can copy the AWCD program, zip it up and send it to you. It is very small - only a couple of floppy discs in size. I can also send a copy of the install instructions as well.
Again, any help would be appreciated.
Thanks,
SpecterFan
  • Windows 98 Second Edition 4.10.2222 A
    AuthenticAMD
    AMD Athlon Processor, MMX, 3DNow, ~1.1GHz
    ATI Radeon 9250 AGP (0x5960) Rev 1
    DirectX 9.0c (4.09.0000.0904)
    DirectDraw Acceleration: Enabled
    Direct3D Acceleration: Enabled
    383 MB RAM
    Direct3d OR OpenGL
    Creative Sound Blaster PCI 128D (WDM)
    Logitech-compatible Mouse (PS/2)
If I missed anything, let me know. Tell me what to look for and where and I'll get back to you.
I realized last night after I posted this that I forgot at least two things:
  • D-Fend Reloaded v0.4.1
    DOSBox v0.72
Sorry for any inconvenience.
Reply 1 of 1, by Qbix
Rank DOSBox Author
DOSBox Author
try a cvs build:
http://cvscompile.aep-emu.de/dosbox.htm
I recently fixed a bug causing the mouse cursor to be invisible in certain programs.
Water flows down the stream
