First post, by chrisdown
I'm trying to run Fatal Racing/Whiplash on 0.72, but I keep on getting this error. It's probably very easily solved - I should state that I have only just picked up DOSBox to play some of my older games lying around the house.
Here is the video: http://www.youtube.com/watch?v=m3GEtMgEPWA
In case you can't see in the vid, here is what I do to load up (if I am doing something wrong or not doing something at all, do tell me).
mount c c:\games\
c:
cd fatal
fatal
Any ideas?
Thanks in advance. 😀
Reply 1 of 2, by MiniMax
Rank Moderator
Moderator
Read my 60 Seconds Guide to DOSBox (and don't just read it - follow it too).
If that doesn't help, come back with details on how you mounted your C and D drives, how you did the install, how you configured sound, music etc.
_________________
Reply 2 of 2, by chrisdown
Worked, cheers.
