First post, by OSH
Hi!
I have big problem with GUS emulation. I've attached a short WAV to describe better, what's going on.
This WAV come from game Sea LEgend, but this isn't very important. This effect (constantly drums beating) appears in almost every game, when I'm using GUS emulation options. Regardless, DOSBOX 0.61, DOSBOX 0.72 or other version. I've played also with gusrate, prebuffer, blocksize, core, cycles - nothing helps. I've decreased cycles to 1 and music doesn't play, but this annoying constantly drums beating is playing! Is any solution to solve this problem or this can't be solved?
    sl_000.wav.mp3
    406.23 KiB
    280 downloads
