Fullscreen (Sparc)
First post, by sergio7
Hi all,
I installed Dosbox-0.72 on my Solaris10 Sparcstation (gcc), works fine, only trying to switch to fullscreen i get the classical :
X Error of failed request: BadMatch (invalid parameter attributes)
Major opcode of failed request: 131 (MIT-SHM)
Minor opcode of failed request: 3 (X_ShmPutImage)
Serial number of failed request: 51
Current serial number in output stream: 52
- same issue with my old Dosbox-0.65 on Sparc. On Solaris 10x86, no problem.
- also, i looked at my SDL (test) : the fullscreen is really available. And another SDL-based app i have supports easily the fullscreen mode.
- i builded also Dosbox without opengl, but that doesn't helped.
Any idea about the way i can try to solve that would be great appreciated...
Cheers,
Sergio
Reply 1 of 14, by Qbix
Rank DOSBox Author
DOSBox Author
have you tried output=overlay ?
DOSBOX_SDL_OUTPUT=overlay ./dosbox
Water flows down the stream
Reply 2 of 14, by sergio7
Hi Qbix,
Fantastic ! It works !
- but the usable part of the window isn't enlarged : now i suspect that is my SDL installation related. But where...
Great thank's,
Cheers,
Sergio
Reply 3 of 14, by Qbix
Rank DOSBox Author
DOSBox Author
hi sergio,
try creating a configfile for dosbox (in dosbox: config -wc ~/.dosboxrc )
and edit that file. you can set the output there as well as well as other options that govern the size of the emulated window
Reply 4 of 14, by sergio7
Hi Obix,
OK : full working !
Thank's greatly to you for your very useful help.
Cheers,
Sergio
Reply 5 of 14, by MiniMax
Rank Moderator
Moderator
Sergio - maybe you an Qbix could arrange for a copy of your build to be made available on the www.dosbox.com site?
_________________
Reply 6 of 14, by wd
Rank DOSBox Author
DOSBox Author
Installation is rather straightforward by using autogen/configure tools.
Reply 7 of 14, by sergio7
Hi MiniMax,
OK : first i'll learn again the best configuration (screen, keyboard) i'll find for Solaris/Sparc, and after that report it here on the forum (or somewhere else ?) ASAP. Maybe also about the build itself if something seems really interesting.
Cheers,
Sergio
Reply 8 of 14, by sergio7
Hi wd
It seems that i bad understand the question from MiniMax : effectively, i can provide my executable itself, if i have a way to upload it. Other hand, as you tell, the build is very easy for everyone on Solaris, even Sparc.
Cheers,
Sergio
Reply 9 of 14, by wd
Rank DOSBox Author
DOSBox Author
The probably biggest problem in getting a *working* dosbox build is the keyboard,
at least that's the part that didn't work out of the box for me.
Reply 10 of 14, by sergio7
Hi wd,
For me (Solaris/Sparc, french Sun keyboard), finally the only thing is to switch "usescancodes" to false in dosbox.conf. After that, mapper.txt can be present or not present, that has no effect, the keyboard is always working.
On any PC with Solaris x86, i remember that i needed only the dosbox executable i builded with gcc, without any config file, and my french keyboard was also working.
Maybe the solution resides in the fact to have SDL builded on the same machine, or similar way ?
Sergio
Reply 11 of 14, by wd
Rank DOSBox Author
DOSBox Author
Yes i know (direct scancode translation is basically only available for win+linux)
but that's the hard part if you don't have a dosbox.conf 😀
Reply 12 of 14, by sergio7
In this case, the easiest is to :
-open an empty file called dosbox.conf ;
- juste type :
[sdl]
usescancodes=false
Save the file, launch dosbox with this file in the same directory : after that, you should be able to type in the dosbox window :
config -wc dosbox.conf.new
(or any name you want)
And you will get a standard dosbox.conf.
Otherwise there are some dosbox.conf examples on the Web.
Sergio
Reply 13 of 14, by wd
Rank DOSBox Author
DOSBox Author
Well i know about how to change the layout 😉
It's just that as far as i remember this was the only thing that didn't work
out of the box, that's why i've mentioned it.
Reply 14 of 14, by Copter
Thanks Qbix. I had similar problem (MIT-SHM, X_ShmPutImage) with Death Rally on Ubuntu Netbook Remix 9.04. Setting output to overlay did the trick 😀
