First post, by Nicht Sehr Gut
- l33t
From "albinovocalist":
I went through the walk through offered at http://netstruck.com/buildxp/. I've done it three times now and it still doesn't work. I emailed him once and he says that I must have missed a step.
The irony of step-by-step guides is that while they make things easier for basic users, they don't take variables into account. IOW, "what do about step 4 when step 3 isn't working".
I all fairness, it sounds like my own "BUILD Games" guide in the "Problem Children" thread may be no help at this point (especially since I don't know where exactly you're stuck...).
To be on the safe side, start with the basics. Run SETUP and configure "Sound Setup" for None for both the "Sound FX" card and "Music" card.
For choose "Screen Setup", choose 320 x 200 (Normal Mode) then save your settings and run BLOOD.EXE. It should run properly (without sound) in 320x200 resolution. Does it?
