First post, by Ohma
Okay, so the computer with the problem is a Vista comp, and the keyboard is (I would assume, given that I'm a US citizen and the computer was bought in the US from a US based company) US layout.
Symptoms of problem:
1. Shift has no effect. (all keys which function are the same regardless of shift being held down/capslock being set or not)
2. Some keys do not type the correct symbol. (] is [, \ is ])
3. Other keys do not function. ([, ', =)
So, yeah, help please? 😜
Reply 1 of 3, by MiniMax
Rank Moderator
Moderator
/me gleefully watches as those damn imperialistic Americans now have to face the same kind of problems he had 25 years ago when trying to use US-only programs and OS's with his Danish keyboard and printer...
_________________
Reply 2 of 3, by indyattic
Is there a known solution for this problem?
The instructions for Dosbox tell me to type a \, but the ability to make my keyboard produce that symbol seems non existent.
Reply 3 of 3, by wd
Rank DOSBox Author
DOSBox Author
Somebody on another thread said that it worked after he installed the
correct keyboard driver, or maybe check the SDL_VIDEODRIVER setting
(search the forum for that).
