First post, by redbear
I am trying to setup some games in dosbox but the problem is that the emulation do not recognized the throttle and the rudder pedals.
My control system is a thrusmaster cougar and the only way i see it works if when i swap axis 3 and 4 bu8t of course my rudder is my thortle and vice versa.
do you have any idea or know any utility i could run to set my controls up?
Thanks in advance.
Reply 2 of 3, by redbear
xpadder ???? what is that?
Any way i use another utility and swap the axis and is working now the utility is dbgl and dosshell.
With dosshell the calibration is without problem and also i don't need to swap the axis it works very nice. but in the other hand dbgl have a problem the calibration of the joy is ok but the throttle and the rudder is a different history. it did not see all the movement range of these perifericals the range is not compled and there is a drift. that is using auto joystick in the programing of the setup file for the game.
If i choose fcs because i have a thrusmaster cougar them it did not see the axes of rudder and throttle
I put a pots here to the guys that are discusing this utility (dbgl) to see what could come here but if you have any recomendation let me know.
Reply 3 of 3, by redbear
no problem i have found the solution. Don't use timed when using cpu to auto or max now i can calibrates the joystick very good. learning this wonderfull tool.
Thanks.
