First post, by MacSchulte
I'm trying to run a Magic-application, written for Dos, in DosBox.
It works, accept for the function keys, which is essential for this application.
How can I fix this?
MacX
How can I fix this?
MacX
do you have an flock key ?
Water flows down the stream
Sorry no. I have a standard iMac-keyboard and I can't see anything like Fn, if that is what you mean.
thanx: MacX
Maybe the key which is now labelled with 'Command'?
Klimawandel.
Can't you just use the DOSBox mapper to move them to other keys?
I'll try this out as soon as I have figured out what this Dosboxmapper is.
thanx a lot.
Look in the README. Something to do with mapping keys to other keys.....
I found that the issue could be solved by switching a toggle in the Apple Systempreferences.
Not a nice situation though, since if you have some music running in iTunes, you need the same buttons for the sound volume level.
Anyway, thanx everyone for their time and suggestions.
MacSchulte
