First post, by cacodemonio
I am trying to use the serial joystick whose picture is attached. I have no idea about the model name, since I bought it for 1 EUR on the streets. I think the retro gaming enthusiast here must know this device.
Under Mandriva 2008.1 (and previous versions) I am able to calibrate it in KDE using a serial to usb adapter. If I connect it to the soundcard game port, it simply does not work.
I cannot however, use it right under Tie Fighter (TF). If I use the adapter, the joystick gets always decalibrated, it goes to the upper left corner, again and again, and I cannot keep it steady. I read the README and tried several joystick options, auto, fcs, ch, but finally settled it to none, so I am playing TF with the mouse.
Has anybody has sucess using this or similar serial devices on linux+dosbox? can anyone tell me how to go through configuring it, modprobing etc...?
Thanks
[tommy@localhost ~]$ uname -aLinux localhost 2.6.24.4-desktop-3mnb #1 SMP Mon May 5 18:09:09 EDT 2008 i686 Intel(R) Pentium(R) 4 CPU 1.60GHz GNU/Linux[tommy@localhost ~]$ cat /proc/cpuinfoprocessor : 0vendor_id : GenuineIntelcpu family : 15model : 2model name : Intel(R) Pentium(R) 4 CPU 1.60GHzstepping : 4cpu MHz : 1600.000cache size : 512 KBfdiv_bug : nohlt_bug : nof00f_bug : nocoma_bug : nofpu : yesfpu_exception : yescpuid level : 2wp : yesflags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm up pebs bts sync_rdtscbogomips : 3202.61clflush size : 64[tommy@localhost ~]$ lspci00:00.0 Host bridge: Intel Corporation 82845 845 [Brookdale] Chipset Host Bridge (rev 03)00:01.0 PCI bridge: Intel Corporation 82845 845 [Brookdale] Chipset AGP Bridge (rev 03)00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev 12)00:1f.0 ISA bridge: Intel Corporation 82801BA ISA Bridge (LPC) (rev 12)00:1f.1 IDE interface: Intel Corporation 82801BA IDE U100 Controller (rev 12)00:1f.2 USB Controller: Intel Corporation 82801BA/BAM USB Controller #1 (rev 12)00:1f.3 SMBus: Intel Corporation 82801BA/BAM SMBus Controller (rev 12)00:1f.4 USB Controller: Intel Corporation 82801BA/BAM USB Controller #1 (rev 12)01:00.0 VGA compatible controller: nVidia Corporation NV34 [GeForce FX 5200] (rev a1)02:01.0 Multimedia audio controller: C-Media Electronics Inc CM8738 (rev 10)02:04.0 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 61)02:04.1 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 61)02:04.2 USB Controller: VIA Technologies, Inc. USB 2.0 (rev 63)02:04.3 FireWire (IEEE 1394): NEC Corporation IEEE 1394 Host Controller (rev 01)02:05.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL-8139/8139C/8139C+ (rev 10)[tommy@localhost ~]$
