Blueetooth on W98lite
First post, by eL_PuSHeR
Hi, a friend of mine is trying to install a bluetooth usb dongle + drivers on a 98lited version of windows. Unfortunately, the installer exits with an error about a DLL (it's an MSI package). We have tried manually unpacking the MSI and looking for the driver ourselves, but Windows cannot find any.
Do you know if there is any generic RFCOMM driver for Win98? I Googled for it and returned nothing. Under WinXP the dongle doesn't even need drivers.
PS - I think the manufacturer could be Cambridge Silicon R
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 1 of 6, by Jorpho
If a generic driver exists, it would surely be on the MSFN boards or mdgx.com . Maybe you can even try asking there.
Can you be more specific about what DLL is missing? Do you mean that you unpacked the MSI and tried to find the specific DLL inside it? (If you're looking for a driver, it will be an .inf file, of course.)
Reply 2 of 6, by eL_PuSHeR
The installer doesn't mention DLL name (stupid windows installers).
I unpacked the MSI looking for an inf file to manually install driver. NO luck.
Intel i7 5960X
8 GB DDR4 (2100)
Reply 3 of 6, by Jorpho
Ah, so it just says a DLL is missing?
In that case you should head over to Sysinternals and get Filemon or Procmon . That ought to tell you what DLL it is failing to find.
Reply 4 of 6, by eL_PuSHeR
My guess is that the installation needs windows installer 3.x to work. My friend has version 2.x
Intel i7 5960X
8 GB DDR4 (2100)
Reply 5 of 6, by Jorpho
Well, yes, that's also quite possible. 🙄 On the other hand, I think you'd get an error message explicitly stating that your version of the Windows installer is out of date if that was the problem, rather than just something about a missing DLL.
It also suddenly occurs to me that something in the installer might need the .NET runtime; funny error messages also show up when that's missing.
Anyway, does the installer for installer 3.x not work under 98lite? Like the .NET runtime, it should be available from any number of places.
Reply 6 of 6, by eL_PuSHeR
I will check the .net issue. Thanks.
In the interim, I have redirected my friend to MSFN forum.
Intel i7 5960X
8 GB DDR4 (2100)
