First post, by freddymc
Hi there!
I tried to run a german learning application (it is called "Budenberg").
It runs fine but in the program you've to press CTRL + PAUSE to cancel the current section.
The program doesn't react to this key combination (in original Win95 DOS this definitely works).
Maybe this is caused by my german keyboard layout? Or should I remap the combination in some way?
Help appreciated...
Thanks & regards,
Fred
