First post, by RayDream
A newbie in programming here,
I had encountered this grp5 illegal call 7 problem as I tried to run an old game developed by taiwanese company 1994 (the game is not tested by dosbox).
The game is called DIF2, dosbox shows grp5 illegal call 7 while vdmsound is able to run it, however the speed will be messed up, playing normal speed in title screen, but a reduced speed in gameplay. I had tried SPEEDSET.exe (a speedup program), however due to the badly programming in the game, it slowed again after some pt in the game.
The game can be downloaded here:
link deleted by MiniMax
Please help!
Reply 6 of 13, by MiniMax
Rank Moderator
Moderator
Seems like it is a problematic game for DOSBox:
http://www.dosbox.com/comp_list.php?showID=1592
_________________
Reply 9 of 13, by rcblanke
Maybe try this altered DOSBox version (as proposed by jmk) for this particular game. Please don't use it for anything else.
    dbdif2.zip
    1.48 MiB
    698 downloads
    special DOSBox build for DIF-2 Mirage Thunder
Reply 11 of 13, by ripsaw8080
Rank DOSBox Author
DOSBox Author
I had an idea of how to make this game more DOSBox-friendly, but it involved hacking the executable, and that's not the best approach. I took the same general idea and turned it into a patch loader program that makes the necessary modifications in memory, so nothing is permanently changed. Run DIF2FIX.COM from the same directory where DIF-2.EXE is located. The included source code has some comments explaining the modifications.
RayDream, please check if the loader works correctly with your original, unmodified executable, as the one I tested with has clearly had its copy protection neutered. The game sometimes locks up when exiting back to DOS, but that happens even without my program.
    DIF2FIX.ZIP
    1.5 KiB
    625 downloads
    Patch loader program allowing DIF-2 to run in standard DOSBox
Reply 12 of 13, by eL_PuSHeR
Great work! Your patch works with official DOSBox 0.72, but I also tried an already cracked executable version.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
