First post, by butterfly
Recently something happened but no configuration was changed at all.
I used to have, and still have, a config file to run a game using a floppy image made up with WinImage.
Such configuration always worked using DOSBox 0.72
Two days ago I run DOSBox 0.72 with the config file named above and I got this error:
"Non posso creare il drive da file", "Cannot create drive from file".
What might have changed?
Perhaps an XP problem?
Anyway I managed it extracting the content of the floppy image to a folder.
WinXP Pro SP3
DOSBox 0.72
Reply 1 of 9, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Maybe the game or the DOSBox FAT handler managed to corrupt the image?
1+1=10
Reply 3 of 9, by butterfly
DosFreak wrote:
or corrupted filesystem on the host?
How can I check that (it's just for curiosity's sake)?
Reply 4 of 9, by MiniMax
Rank Moderator
Moderator
Maybe http://chitchat.at.infoseek.co.jp/vmware/vfd.html
_________________
Reply 5 of 9, by butterfly
Uhm... i'm a bit puzzled. maybe the .IMG file is corrupted cos I succeeded to mount it using the suggested program but the virtual floppy disk looks blank...
Reply 6 of 9, by MiniMax
Rank Moderator
Moderator
Can you mount a different (good) image with VFD?
_________________
Reply 7 of 9, by butterfly
Uhm... No, I can't.
Reply 8 of 9, by ADDiCT
WinImage. I'd rather use a program like WinImage than to install a device driver (which VFD does, i believe - it seems to be similar to Daemon Tools) on my system. (;
Reply 9 of 9, by butterfly
Ok, right, for some reasons the image is ruined
